About stability and regularization of ill-posed elliptic Cauchy problems: The case of C1,1 domains - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Mathematical Modelling and Numerical Analysis Année : 2010
This paper is devoted to a conditional stability estimate related to the ill-posed Cauchy problems for the Laplace's equation in domains with C 1,1 boundary. It is an extension of an earlier result of [Phung, ESAIM: COCV 9 (2003) 621-635] for domains of class C∞. Our estimate is established by using a Carleman estimate near the boundary in which the exponential weight depends on the distance function to the boundary. Furthermore, we prove that this stability estimate is nearly optimal and induces a nearly optimal convergence rate for the method of quasi-reversibility introduced in [Lattès and Lions, Dunod (1967)] to solve the ill-posed Cauchy problems. © EDP Sciences, SMAI, 2010.
hal-00873056 , version 1 (15-10-2013)
Laurent Bourgeois. About stability and regularization of ill-posed elliptic Cauchy problems: The case of C1,1 domains. ESAIM: Mathematical Modelling and Numerical Analysis, 2010, 44 (4), pp.715-735. ⟨10.1051/m2an/2010016⟩. ⟨hal-00873056⟩
135 Consultations
0 Téléchargements
