An improved multimodal approach for non-uniform acoustic waveguides - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IMA Journal of Applied Mathematics Année : 2008
This paper explores from the point of view of numerical analysis a method for solving the acoustic time-harmonic wave equation in a locally non-uniform 2D waveguide. The multimodal method is based on a spectral description of the acoustic field in each transverse section of the guide, using Fourier-like series. In the case of sound-hard boundaries, the weak point of the method lies in the poor convergence of such series due to a poor approximation of the field near the boundaries. A remedy was proposed by Athanassoulis & Belibassakis (1999, J. Fluid Mech., 389, 275-301), where the convergence is improved thanks to the use of enhanced series. The present paper proposes a theoretical analysis of their idea and studies further improvements. For a general model which includes different kinds of non-uniformity (varying cross section, bend and inhomogeneous medium), a hybrid spectral/variational formulation is introduced. Error estimates are provided for a semi-discretized problem which concerns the effect of spectral truncation. These estimates are confirmed by numerical results. © The Author 2008. Published by Oxford University Press on behalf of the Institute of Mathematics and its Applications. All rights reserved.
hal-00873082 , version 1 (17-10-2013)
Christophe Hazard, Éric Lunéville. An improved multimodal approach for non-uniform acoustic waveguides. IMA Journal of Applied Mathematics, 2008, 73 (4), pp.668-690. ⟨10.1093/imamat/hxn006⟩. ⟨hal-00873082⟩
169 Consultations
0 Téléchargements
