On the mutual nearest neighbors estimate in regression - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Machine Learning Research Année : 2013
Motivated by promising experimental results, this paper investigates the theoretical properties of a recently proposed nonparametric estimator, called the Mutual Nearest Neighbors rule, which estimates the regression function m(x) = E[Y vertical bar X = x] as follows: first identify the k nearest neighbors of x in the sample D-n, then keep only those for which x is itself one of the k nearest neighbors, and finally take the average over the corresponding response variables. We prove that this estimator is consistent and that its rate of convergence is optimal. Since the estimate with the optimal rate of convergence depends on the unknown distribution of the observations, we also present adaptation results by data-splitting.
Fichier non déposé
hal-00874050 , version 1 (17-10-2013)
  • HAL Id : hal-00874050 , version 1
Arnaud Guyader, Nick Hengartner. On the mutual nearest neighbors estimate in regression. Journal of Machine Learning Research, 2013, 14, pp.2361-2376. ⟨hal-00874050⟩
116 Consultations
0 Téléchargements
