A Soft Handover for Service Delivery in Intermittently Connected Hybrid Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ali Makke
  • Fonction : Auteur
  • PersonId : 930120
Yves Mahéo
Today, handheld devices equipped with Wi-Fi interfaces are used intensively by a huge number of people every day. These devices can form intermittently connected mobile ad hoc networks spontaneously. These networks appear as a relevant solution to extend a pre-existing infrastructure-based network composed of several access points in view of providing nomadic people with application services in a wide area. In such hybrid networks, intermittent connections are prevalent, and end-to-end paths between clients and providers cannot be maintained all the time. Thus, the communications must be achieved following a "store, carry and forward" principle. In this paper, we present a new soft handover mechanism dedicated to service delivery in such hybrid networks. This handover solution exploits several pieces of information, such as the message propagation time, the path stability, and the mobility degree of intermediate nodes in order to select the most appropriate access point(s) to forward a response to a given mobile client.
mobilware12lesommer.pdf (1.1 Mo) Télécharger le fichier
hal-00874634 , version 1 (18-10-2013)
Nicolas Le Sommer, Ali Makke, Yves Mahéo. A Soft Handover for Service Delivery in Intermittently Connected Hybrid Networks. 5th International Conference on Mobile Wireless Middleware, Operating Systems, and Applications (Mobilware 2012), Nov 2012, Berlin, Germany. pp.122-135, ⟨10.1007/978-3-642-36660-4_9⟩. ⟨hal-00874634⟩
380 Consultations
240 Téléchargements
