Convergence of a Discontinuous Galerkin scheme for the mixed time domain Maxwell's equations in dispersive media. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IMA Journal of Numerical Analysis Année : 2013
This work is about the numerical solution of the time-domain Maxwell's equations in dispersive propagation media by a discontinuous Galerkin time-domain method. The Debye model is used to describe the dispersive behaviour of the media. The resulting system of differential equations is solved using a centred-flux discontinuous Galerkin formulation for the discretization in space and a second-order leapfrog scheme for the integration in time. The numerical treatment of the dispersive model relies on an auxiliary differential equation approach similar to that which is adopted in the finite difference time-domain method. Stability estimates are derived through energy considerations and convergence is proved for both the semidiscrete and the fully discrete schemes.
Fichier non déposé
hal-00874752 , version 1 (18-10-2013)
Stephane Lanteri, Claire Scheid. Convergence of a Discontinuous Galerkin scheme for the mixed time domain Maxwell's equations in dispersive media.. IMA Journal of Numerical Analysis, 2013, 33 (2), pp.432-459. ⟨10.1093/imanum/drs008⟩. ⟨hal-00874752⟩
128 Consultations
0 Téléchargements
