Numerical study of drag reduction of a car model by active control using mico-jets - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The goal of the present work is to evaluate some possibilities of drag reduction of motor vehicles through the integration of a network of micro-jets. To this end, numerical simulations of SVV-LES (Spectral Vanishing Viscosity - Large-Eddy Simulation) type are carried out for the turbulent flow generated by a square back Ahmed body. The results obtained for two different configurations of the drag reduction system show the influence of the presence of the micro-jets on the flow and their ability to significantly reduce the drag forces (up to 10% in case of synthetic micro-jets).
Fichier non déposé
hal-00875715 , version 1 (22-10-2013)
  • HAL Id : hal-00875715 , version 1
Noele Peres, Richard Pasquetti. Numerical study of drag reduction of a car model by active control using mico-jets. CFM 2013 - 21ème Congrès Français de Mécanique, Aug 2013, Bordeaux, France. ⟨hal-00875715⟩
150 Consultations
0 Téléchargements
