A posteriori analysis of Chorin-Temam scheme for Stokes equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Comptes Rendus. Mathématique Année : 2013
We consider Chorin-Temam scheme (the simplest pressure-correction projection method) for the time-discretization of an unstationary Stokes problem. Inspired by the analyses of the Backward Euler scheme performed by C.Bernardi and R.Verfürth, we derive a posteriori estimators for the error on the velocity gradient in L2 norm. Our invesigation is supported by numerical experiments.
boyaval-picasso-final.pdf (844.73 Ko) Télécharger le fichier
hal-00876069 , version 1 (23-10-2013)
Sébastien Boyaval, M. Picasso. A posteriori analysis of Chorin-Temam scheme for Stokes equations. Comptes Rendus. Mathématique, 2013, 351 (23-24), pp.931-936. ⟨10.1016/j.crma.2013.10.026⟩. ⟨hal-00876069⟩
370 Consultations
416 Téléchargements
