Image inpainting: Overview and recent advances - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Signal Processing Magazine Année : 2014
Image inpainting refers to the process of restoring missing or damaged areas in an image. This field of research has been very active over the past years, boosted by numerous applications: restoring images from scratches or text overlays, loss concealment in a context of impaired image transmission, object removal in a context of editing, disocclusion in image-based rendering of viewpoints different from those captured by the cameras. This article surveys the theoretical foundations, the different categories of methods, and illustrates the main applications
Fichier non déposé
hal-00876076 , version 1 (23-10-2013)
  • HAL Id : hal-00876076 , version 1
Christine Guillemot, Olivier Le Meur. Image inpainting: Overview and recent advances. IEEE Signal Processing Magazine, 2014. ⟨hal-00876076⟩
2279 Consultations
0 Téléchargements
