Margin conditions for vector quantization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2014
In this report, oracle inequalities on the excess risk of the empirical risk minimizer in the quantization framework are derived. These inequalities are based on conditions which may be thought of as margin type conditions, such as one derived in the statistical learning framework. Furthermore, these inequalities derive from innovative chaining techniques and its use for Dudley's entropy integral.
Margin_conditions_for_vector_quantization.pdf (371.52 Ko) Télécharger le fichier
hal-00877093 , version 1 (26-10-2013)
hal-00877093 , version 2 (25-04-2014)
Clément Levrard. Margin conditions for vector quantization. 2014. ⟨hal-00877093v2⟩
252 Consultations
121 Téléchargements
