A Theory of Refractive Photo-Light-Path Triangulation
3D reconstruction of transparent refractive objects like a plastic bottle is challenging: they lack appearance related visual cues and merely reflect and refract light from the surrounding environment. Amongst several approaches to reconstruct such objects, the seminal work of Light-Path triangulation is highly popular because of its general applicability and analysis of minimal scenarios. A light-path is defined as the piece-wise linear path taken by a ray of light as it passes from source, through the object and into the camera. Transparent refractive objects not only affect the geometric configuration of light-paths but also their radiometric properties. In this paper, we describe a method that combines both geometric and radiometric information to do reconstruction. We show two major consequences of the addition of radiometric cues to the light-path setup. Firstly, we extend the case of scenarios in which reconstruction is plausible while reducing the minimal requirements for a unique reconstruction. This happens as a consequence of the fact that radiometric cues add an additional known variable to the already existing system of equations. Secondly, we present a simple algorithm for reconstruction, owing to the nature of the radiometric cue. We present several synthetic experiments to validate our theories, and show high quality reconstructions in challenging scenarios.
Origin : Publisher files allowed on an open archive
