Attribute-Based Classification with Label-Embedding - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Attributes are an intermediate representation whose purpose is to enable parameter sharing between classes, a must when training data is scarce. We propose to view attribute-based image classification as a label-embedding problem: each class is embedded in the space of attribute vectors. We introduce a function which measures the compatibility between an image and a label embedding. The parameters of this function are learned on a training set of labeled samples to ensure that, given an image, the correct class has a higher compatibility than the incorrect ones. Experimental results on two standard image classification datasets are presented, resp. on the Animals With Attributes and on Caltech-UCSD-Birds datasets.
orl2013_submission_1.pdf (158.83 Ko) Télécharger le fichier
Format : Figure, Image
hal-00903502 , version 1 (12-11-2013)
  • HAL Id : hal-00903502 , version 1
Zeynep Akata, Florent Perronnin, Zaid Harchaoui, Cordelia Schmid. Attribute-Based Classification with Label-Embedding. NIPS 2013 Workshop on Output Representation Learning, Neural Information Processing Systems (NIPS) Foundation, Dec 2013, Lake Tahoe, United States. ⟨hal-00903502⟩
855 Consultations
678 Téléchargements
