Optimal crowd editing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Graphical Models Année : 2014
Simulating realistic crowd behaviors is a challenging problem in computer graphics. Yet, several satisfying simulation models exhibiting natural pedestrians or group emerging behaviors exist. Choosing among these model generally depends on the considered crowd density or the topology of the environment. Conversely, achieving a user-desired kinematic or dynamic pattern at a given instant of the simulation reveals to be much more tedious. In this paper, a novel generic control methodology is proposed to solve this crowd editing issue. Our method relies on an adjoint formulation of the underlying optimization procedure. It is independent to a certain extent of the choice of the simulation model, and is designed to handle several forms of constraints. A variety of examples attesting the benefits of our approach are proposed, along with quantitative performance measures.
paper.pdf (6.94 Mo) Télécharger le fichier
hal-00904008 , version 1 (13-11-2013)
  • HAL Id : hal-00904008 , version 1
Pierre Allain, Nicolas Courty, Thomas Corpetti. Optimal crowd editing. Graphical Models, 2014, 76 (1), pp.1--16. ⟨hal-00904008⟩
523 Consultations
273 Téléchargements
