Isomorphisms and Serre's reduction of linear systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we give an explicit characterization of isomorphic finitely presented modules in terms of certain inflations of their presentation matrices. In particular cases, this result yields a characterization of isomorphic modules as the completion problem characterizing Serre's reduction, i.e., of the possibility to find a presentation of the module defined by fewer generators and fewer relations. This completion problem is shown to induce different isomorphisms between the modules finitely presented by the matrices defining the inflations. Finally, we show how Serre's reduction implies the existence of a certain idempotent endomorphism of the finitely presented module, i.e., that Serre's reduction implies a particular decomposition, proving the converse of a result obtained in [7].
Fichier non déposé
hal-00904038 , version 1 (13-11-2013)
  • HAL Id : hal-00904038 , version 1
Thomas Cluzeau, Alban Quadrat. Isomorphisms and Serre's reduction of linear systems. nDS 2013, Sep 2013, Erlangen, Germany. ⟨hal-00904038⟩
153 Consultations
0 Téléchargements
