Towards Certifying Network Calculus - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Network Calculus (NC) is an established theory for determining bounds on message delays and for dimensioning buffers in the design of networks for embedded systems. It is supported by academic and industrial tool sets and has been widely used, including for the design and certification of the Airbus A380 AFDX backbone. However, while the theory of NC is generally well understood, results produced by existing tools have to be trusted. We report here on work towards using the interactive proof assistant Isabelle/HOL for certifying the results of NC computations. In a nutshell, the NC tool outputs a trace of the calculations it performs, as well as their results. The validity of the trace is then established offline by a trusted checker.
final.pdf (123.15 Ko) Télécharger le fichier
hal-00904796 , version 1 (15-11-2013)
Etienne Mabille, Marc Boyer, Loic Féjoz, Stephan Merz. Towards Certifying Network Calculus. ITP - 4th International Conference on Interactive Theorem Proving, Jul 2013, Rennes, France. pp.484-489, ⟨10.1007/978-3-642-39634-2_37⟩. ⟨hal-00904796⟩
447 Consultations
150 Téléchargements
