Bridging the Chasm between Executable Metamodeling and Models of Computation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The complete and executable definition of a Domain Specific Language (DSL) relies on the specification of two essential facets: a model of the domain-specific concepts with actions and their semantics; a scheduling model that orchestrates the actions of a domain-specific model. Metamodels can capture the former facet, while Models of Computation (MoCs) capture the latter facet. Unfortunately, theories and tools for metamodeling and MoCs have evolved independently, creating a cultural and technical chasm between the two communities. Consequently, there is currently no framework to explicitly model and compose both facets of a DSL. This paper introduces a new framework to bridge a metamodel and a MoC in a modular fashion. This bridge allows (i) the complete and executable definition of a DSL, (ii) the reuse of MoCs for different domain-specific metamodels, and (iii) the use of different MoCs for a given metamodel, to cope with variation points of a DSL.
2012BridgingTheChasm.pdf (222.17 Ko) Télécharger le fichier
hal-00905067 , version 1 (15-11-2013)
  • HAL Id : hal-00905067 , version 1
Benoit Combemale, Cécile Hardebolle, Christophe Jacquet, Frédéric Boulanger, Benoit Baudry. Bridging the Chasm between Executable Metamodeling and Models of Computation. 5th International Conference, SLE 2012, Sep 2012, Desden, Germany. pp.184-203. ⟨hal-00905067⟩
443 Consultations
435 Téléchargements
