HITS and IRISA at MediaEval 2013: Search and Hyperlinking Task - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper describes our approach and results in the hyperlinking sub-task at MediaEval 2013. A two step method is implemented where the fi rst step consists in establishing a shortlist of relevant videos. In the second step, a target segment is selected from each video in the shortlist. We focus on target selection comparing two distinct strategies. The fi rst one exploits a bipartite graph relating utterances and words to find the most relevant utterances from which segments are derived. The second one uses explicit topic segmentation, whether hierarchical or not, to select the target segments.
mediaeval2013_submission_40.pdf (65.32 Ko) Télécharger le fichier
hal-00906249 , version 1 (19-11-2013)
  • HAL Id : hal-00906249 , version 1
Camille Guinaudeau, Anca-Roxana Simon, Guillaume Gravier, Pascale Sébillot. HITS and IRISA at MediaEval 2013: Search and Hyperlinking Task. MediaEval working notes, 2013, Spain. pp.2. ⟨hal-00906249⟩
312 Consultations
108 Téléchargements
