Fragmentations with pitch, rhythm and parallelism constraints for variation matching - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Composers commonly employ ornamentation and elaboration techniques to generate varied versions of an initial core melodic idea. Dynamic programming techniques, based on edit operations, are used to find similarities between melodic strings. However, replacements, insertions and deletion may give non-musically pertinent similarities, especially if rhythmic or metrical structure is not considered. We propose, herein, to compute the similarity between a reduced query and a melody employing only fragmentation operations. Such fragmentations transform one note from the reduced query into a possible large set of notes, taking into account metrical, pitch and rhythm constraints, as well as elementary parallelism information. We test the proposed algorithm on two prototypical ''theme and variations'' piano pieces by W. A. Mozart and show that the proposed constrained fragmentation operations are capable of detecting variations with high sensitivity and specificity.
variations-cmmr-2013-lncs.pdf (1.14 Mo) Télécharger le fichier
hal-00906462 , version 1 (19-11-2013)
hal-00906462 , version 2 (21-01-2015)
Mathieu Giraud, Ken Déguernel, Emilios Cambouropoulos. Fragmentations with pitch, rhythm and parallelism constraints for variation matching. International Symposium on Computer Music Multidisciplinary Research (CMMR), Oct 2013, Marseille, France. pp.298-312, ⟨10.1007/978-3-319-12976-1_19⟩. ⟨hal-00906462v2⟩
577 Consultations
984 Téléchargements
