An accurate cartesian method for incompressible flows with moving boundaries - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Communications in Computational Physics Année : 2013
An accurate cartesian method is devised to simulate incompressible viscous flows past an arbitrary moving body. The Navier-Stokes equations are spatially discretized onto a fixed Cartesian mesh. The body is taken into account via the ghost-cell method and the so-called penalty method, resulting in second-order accuracy in velocity. The accuracy and the efficiency of the solver are tested through two-dimensional reference simulations. To show the versatility of this scheme we simulate a three-dimensional self propelled jellyfish prototype
article.pdf (2.03 Mo) Télécharger le fichier
hal-00906897 , version 1 (20-11-2013)
  • HAL Id : hal-00906897 , version 1
Michel Bergmann, Jessica Hovnanian, Angelo Iollo. An accurate cartesian method for incompressible flows with moving boundaries. Communications in Computational Physics, 2013. ⟨hal-00906897⟩
14496 Consultations
1092 Téléchargements
