Phase Recovery, MaxCut and Complex Semidefinite Programming - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematical Programming, Series A Année : 2015
Phase retrieval seeks to recover a signal x from the amplitude |Ax| of linear measurements. We cast the phase retrieval problem as a non-convex quadratic program over a complex phase vector and formulate a tractable relaxation (called PhaseCut) similar to the classical MaxCut semidefinite program. We solve this problem using a provably convergent block coordinate descent algorithm whose structure is similar to that of the original greedy algorithm in Gerchberg-Saxton, where each iteration is a matrix vector product. Numerical results show the performance of this approach over three different phase retrieval problems, in comparison with greedy phase retrieval algorithms and matrix completion formulations.
hal-00907535 , version 1 (21-11-2013)
Irène Waldspurger, Alexandre d'Aspremont, Stéphane Mallat. Phase Recovery, MaxCut and Complex Semidefinite Programming. Mathematical Programming, Series A, 2015, 149 (1-2), pp.47-81. ⟨10.1007/s10107-013-0738-9⟩. ⟨hal-00907535⟩
468 Consultations
0 Téléchargements
