Energy-preserving integrators for stochastic Poisson systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Communications in Mathematical Sciences Année : 2014
David Cohen
  • Fonction : Auteur
  • PersonId : 963424
A new class of energy-preserving numerical schemes for stochastic Hamiltonian systems with non-canonical structure matrix (in the Stratonovich sense) is proposed. These numerical integrators are of mean-square order one and also preserve quadratic Casimir functions.
cohendujardin.preprint.pdf (396.28 Ko) Télécharger le fichier
hal-00907890 , version 1 (25-11-2013)
David Cohen, Guillaume Dujardin. Energy-preserving integrators for stochastic Poisson systems. Communications in Mathematical Sciences, 2014, 12 (8), pp.17. ⟨10.4310/CMS.2014.v12.n8.a7⟩. ⟨hal-00907890⟩
229 Consultations
242 Téléchargements
