The use of virtual reality for episodic memory assessment: effects of active navigation. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Experimental Psychology Année : 2011
Episodic memory was assessed using Virtual Reality (VR). Forty-four (44) subjects visualized a target virtual apartment containing specific objects in each room. Then they visualized a second virtual apartment comprised of specific objects and objects shared by the two apartments. Subjects navigated in the virtual apartments in one of the following two conditions: active and passive. Four main episodic memory components were scored from the VR exposures: (1) learning effect; (2) active forgetting effect; (3) strategies at encoding and at retrieval; and (4) false recognitions (FRs). The effect of navigation mode (active vs. passive) on each memory component was examined. Active subjects had better learning and retrieval (recognition hits) performances compared to passive subjects. A beneficial effect of active navigation was also observed on the source-based FR rates. Active subjects made fewer source-based FRs compared to passive subjects. These overall results for the effect of active navigation are discussed in terms of the distinction between item-specific and relational processing.
Fichier non déposé
hal-00907977 , version 1 (22-11-2013)
Hélène Sauzéon, Prashant Arvind Pala, Florian Larrue, Gregory Wallet, Marie Déjos, et al.. The use of virtual reality for episodic memory assessment: effects of active navigation.. Experimental Psychology, 2011, 59 (2), pp.99-108. ⟨10.1027/1618-3169/a000131⟩. ⟨hal-00907977⟩
Collections
CNRS INRIA INRIA2
239 Consultations
0 Téléchargements
