Kadeploy3: Efficient and Scalable Operating System Provisioning for Clusters - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue USENIX Association Année : 2013
Emmanuel Jeanvoine
  • Fonction : Auteur
  • PersonId : 847304
Luc Sarzyniec
  • Fonction : Auteur
  • PersonId : 925508
Lucas Nussbaum
Installing an operating system can be very tedious when it must be repro- duced on several computers, for instance, on large scale clusters. Since it is not realistic to install the nodes independently, disk cloning or imaging with tools such as Clonezilla[1], Rocks [5], SystemImager [6] or xCAT [8] is a com- mon approach. In that case the administrator must keep updated only one node (sometimes called golden node), that will be replicated to other nodes. This article presents Kadeploy3, a tool designed to perform operating system provi- sioning using disk imaging and cloning. Thanks to its e ciency, scalability, and reliability, it is particularly suited for large scale clusters.
kadeploy3_login2013.pdf (181.3 Ko) Télécharger le fichier
hal-00909111 , version 1 (25-11-2013)
  • HAL Id : hal-00909111 , version 1
Emmanuel Jeanvoine, Luc Sarzyniec, Lucas Nussbaum. Kadeploy3: Efficient and Scalable Operating System Provisioning for Clusters. USENIX Association, 2013, 38 (1), pp.38-44. ⟨hal-00909111⟩
333 Consultations
281 Téléchargements
