Persistent control of a superconducting qubit by stroboscopic measurement feedback - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Physical Review X Année : 2013
Emmanuel Flurin
David Darson
François Mallet
Benjamin Huard
Making a system state follow a prescribed trajectory despite fluctuations and errors commonly consists of monitoring an observable (temperature, blood-glucose level, etc.) and reacting on its controllers (heater power, insulin amount, etc.). In the quantum domain, there is a change of paradigm in feedback, since measurements modify the state of the system, most dramatically when the trajectory goes through superpositions of measurement eigenstates. Here, we demonstrate the stabilization of an arbitrary trajectory of a superconducting qubit by measurement-based feedback. The protocol benefits from the long coherence time (T2>10 μs) of the 3D transmon qubit, the high efficiency (82%) of the phase-preserving Josephson amplifier, and fast electronics that ensure less than 500 ns total delay. At discrete time intervals, the state of the qubit is measured and corrected in case an error is detected. For Rabi oscillations, where the discrete measurements occur when the qubit is supposed to be in the measurement pointer states, we demonstrate an average fidelity of 85% to the targeted trajectory. For Ramsey oscillations, which do not go through pointer states, the average fidelity reaches 76%. Incidentally, we demonstrate a fast reset protocol that allows us to cool a 3D transmon qubit down to 0.6% in the excited state.
Campagne-stabtraj.pdf (758.07 Ko) Télécharger le fichier
hal-00909975 , version 1 (27-11-2013)
Philippe Campagne-Ibarcq, Emmanuel Flurin, Nicolas Roch, David Darson, Pascal Morfin, et al.. Persistent control of a superconducting qubit by stroboscopic measurement feedback. Physical Review X, 2013, 3 (2), pp.021008. ⟨10.1103/PhysRevX.3.021008⟩. ⟨hal-00909975⟩
859 Consultations
553 Téléchargements
