Residual and Equilibrated Error Estimators for Magnetostatic Problems Solved by Finite Element Method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Magnetics Année : 2013
In finite element computations, the choice of the mesh is crucial to obtain accurate solutions. In order to evaluate the quality of the mesh, a posteriori error estimators can be used. In this paper, we develop residual-based error estimators for magnetostatic problems with both classical formulations in term of potentials used, as well as the equilibrated error estimator. We compare their behaviors on some numerical applications, to understand the interest of each of them in the remeshing process.
Fichier non déposé
hal-00910314 , version 1 (27-11-2013)
Zuqi Tang, Yvonnick Le Menach, Emmanuel Creusé, Serge Nicaise, Francis Piriou, et al.. Residual and Equilibrated Error Estimators for Magnetostatic Problems Solved by Finite Element Method. IEEE Transactions on Magnetics, 2013, 49 (12), pp.5715-5723. ⟨10.1109/TMAG.2013.2271993⟩. ⟨hal-00910314⟩
219 Consultations
0 Téléchargements
