Residual Based a Posteriori Error Estimators for Harmonic A/φ and T/Ω Formulations in Eddy Current Problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Magnetics Année : 2013
For eddy current problems, potential formulations are widely used nowadays. In this paper, residual based a posteriori error estimators are introduced to evaluate the discretization error in the finite element calculation in both case of A /φ and T /Ω harmonic formulations. A device with eddy currents is studied in order to show the efficiency of the proposed estimators.
Fichier non déposé
hal-00910319 , version 1 (27-11-2013)
Zuqi Tang, Yvonnick Le Menach, Emmanuel Creusé, Serge Nicaise, Francis Piriou, et al.. Residual Based a Posteriori Error Estimators for Harmonic A/φ and T/Ω Formulations in Eddy Current Problems. IEEE Transactions on Magnetics, 2013, 49 (5), pp.1721-1724. ⟨10.1109/TMAG.2013.2241408⟩. ⟨hal-00910319⟩
184 Consultations
0 Téléchargements
