Exploiting rateless codes and belief propagation to infer identity of polluters in MANET - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Mobile Computing Année : 2014
We consider the following problem: nodes in a MANET must disseminate data chunks using rateless codes but some nodes are assumed to be malicious, i.e., before transmitting a coded packet they may modify its payload. Nodes receiving corrupted coded packets are prevented from correctly decoding the original chunk. We propose SIEVE, a fully distributed technique to identify malicious nodes.
SIEVE - TMC2013.pdf (1.32 Mo) Télécharger le fichier
hal-00911724 , version 1 (28-04-2015)
Rossano Gaeta, Marco Grangetto, Riccardo Loti. Exploiting rateless codes and belief propagation to infer identity of polluters in MANET. IEEE Transactions on Mobile Computing, 2014, pp.1482 - 1494. ⟨10.1109/TMC.2013.137⟩. ⟨hal-00911724⟩
Collections
INRIA INRIA2
48 Consultations
136 Téléchargements
