An extension of the target theory in biology applied to system reliability - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2014
We consider rough products produced by a factory. Each product coming from the plant has m vital elements and some elements can be damaged. To obtain a perfect product (i.e. all the constitutive m elements are safe) all the damaged elements are repaired and a test phase follows. The result of this two-steps procedure is random. We suppose that the number Zk of non-damaged elements is a Markov chain valued in the set {0,1,...,m}, where k is the number of applied repairing-test phases. We have a qualitative result which says that if the repair phase is efficient then P(Zk=m) is close to 1. As for production of a large number n of products, the former result allows us to give conditions under which either the n elements or a fraction of these n elements are (is) safe after the application of k previous maintenance phases.
Target_system_reliability-19mai-12.pdf (295.47 Ko) Télécharger le fichier
hal-00911872 , version 1 (30-11-2013)
  • HAL Id : hal-00911872 , version 1
Thierry Bastogne, Pierre Vallois. An extension of the target theory in biology applied to system reliability. Fouad El Ouardighi and Konstantin Kogan. Models and Methods in Economics and Management Science: Essays in Honor of Charles S. Tapiero, Springer, pp.155-181, 2014, International Series in Operations Research & Management Science, 978-3-319-00668-0. ⟨hal-00911872⟩
253 Consultations
225 Téléchargements
