Solving generalized eigenvalue problems on the interfaces to build a robust two-level FETI method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Comptes rendus de l'Académie des sciences. Série I, Mathématique Année : 2013
FETI is a very popular method, which has proved to be extremely efficient on many large-scale industrial problems. One drawback is that it performs best when the decomposition of the global problem is closely related to the parameters in equations. This is somewhat confirmed by the fact that the theoretical analysis goes through only if some assumptions on the coefficients are satisfied. We propose here to build a coarse space for which the convergence rate of the two-level method is guaranteed regardless of any additional assumptions. We do this by identifying the problematic modes using generalized eigenvalue problems.
Fichier non déposé
hal-00912307 , version 1 (01-12-2013)
Nicole Spillane, Dolean Victorita, Hauret Patrice, Frédéric Nataf, Rixen Daniel. Solving generalized eigenvalue problems on the interfaces to build a robust two-level FETI method. Comptes rendus de l'Académie des sciences. Série I, Mathématique, 2013, 351 (5-6), pp.197-201. ⟨10.1016/j.crma.2013.03.010⟩. ⟨hal-00912307⟩
239 Consultations
0 Téléchargements
