Fair Scheduling in Cellular Systems in the Presence of Noncooperative Mobiles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE/ACM Transactions on Networking Année : 2014
We consider the problem of 'fair' scheduling the resources to one of the many mobile stations by a centrally controlled base station (BS). The BS is the only entity taking decisions in this framework based on truthful information from the mobiles on their radio channel. We study the well-known family of parametric -fair scheduling problems from a gametheoretic perspective in which some of the mobiles may be noncooperative. We first show that if the BS is unaware of the noncooperative behavior from the mobiles, the noncooperative mobiles become successful in snatching the resources from the other cooperative mobiles, resulting in unfair allocations. If the BS is aware of the noncooperative mobiles, a new game arises with BS as an additional player. It can then do better by neglecting the signals from the noncooperative mobiles. The BS, however, becomes successful in eliciting the truthful signals from the mobiles only when it uses additional information (signal statistics). This new policy along with the truthful signals from mobiles forms a Nash Equilibrium (NE) which we call a Truth Revealing Equilibrium. Finally, we propose new iterative algorithms to implement fair scheduling policies that robustify the otherwise non-robust (in presence of noncooperation) fair scheduling algorithms.
kavitha-ton.pdf (273.98 Ko) Télécharger le fichier
hal-00913209 , version 1 (10-12-2013)
Veeraruna Kavitha, Eitan Altman, Rachid El-Azouzi, Rajesh Sundaresan. Fair Scheduling in Cellular Systems in the Presence of Noncooperative Mobiles. IEEE/ACM Transactions on Networking, 2014, 22 (2), pp.580-594. ⟨10.1109/TNET.2013.2253562⟩. ⟨hal-00913209⟩
221 Consultations
169 Téléchargements
