VMS- and OES-based hybrid simulations of bluff body flows - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Flows past bluff bodies show turbulent near wall behavior in various conditions. For example, for a high Reynolds incident flow, the boundary layer at front side of a circular cylinder may show a transition to a turbulent boundary layer. After separation, the back of the cylinder is in contact with the turbulent wake. Analogously, the turbulent wake of a first obstacle can hit the front of a second one.
Extended_Abstract_ERCOFTAC_2013.pdf (191.45 Ko) Télécharger le fichier
hal-00914023 , version 1 (04-12-2013)
  • HAL Id : hal-00914023 , version 1
Carine Moussaed, Stephen F. Wornom, Bruno Koobus, Alain Dervieux, T. Deloze, et al.. VMS- and OES-based hybrid simulations of bluff body flows. ERCOFTAC Symposium on Unsteady Separation in Fluid-Structure Interaction, Jun 2013, Mykonos, Greece. ⟨hal-00914023⟩
160 Consultations
190 Téléchargements
