On the identification of defects in a periodic waveguide from far field data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Inverse Problems Année : 2014
The aim of this paper is to apply the Linear Sampling Method and the Factorization Method to retrieve some defects in a known periodic 2D waveguide from scattering data. More precisely, some far field approximations of these two sampling methods are derived. They amount to consider the so-called propagating Floquet modes as incident waves. The efficiency of the far field formulation of the LSM is shown with the help of some numerical experiments.
article_bourgeois_fliss_rev_cor.pdf (730.23 Ko) Télécharger le fichier
hal-00914674 , version 1 (05-12-2013)
hal-00914674 , version 2 (01-09-2014)
Laurent Bourgeois, Sonia Fliss. On the identification of defects in a periodic waveguide from far field data. Inverse Problems, 2014, 30 (9), ⟨10.1088/0266-5611/30/9/095004⟩. ⟨hal-00914674v2⟩
270 Consultations
555 Téléchargements
