Large deviations for the Ornstein-Uhlenbeck process with shift - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Advances in Applied Probability Année : 2015
Bernard Bercu
  • Fonction : Auteur
  • PersonId : 845707
Adrien Richou
We investigate the large deviation properties of the maximum likelihood estimators for the Ornstein-Uhlenbeck process with shift. We estimate simultaneously the drift and shift parameters. On the one hand, we establish a large deviation principle for the maximum likelihood estimates of the drift and shift parameters. Surprisingly, we find that the drift estimator shares the same large deviation principle as the one previously established for the Ornstein-Uhlenbeck process without shift. Sharp large deviation principles are also provided. On the other hand, we show that the maximum likelihood estimator of the shift parameter satisfies a large deviation principle with a very unusual implicit rate function.
BRSOUP2014V2-ArXiv.pdf (331.51 Ko) Télécharger le fichier
hal-00915936 , version 1 (12-12-2013)
hal-00915936 , version 2 (04-09-2014)
  • HAL Id : hal-00915936 , version 2
Bernard Bercu, Adrien Richou. Large deviations for the Ornstein-Uhlenbeck process with shift. Advances in Applied Probability, 2015, 47 (3), pp.1--22. ⟨hal-00915936v2⟩
Relations
Collections
CNRS IMB INSMI
143 Consultations
226 Téléchargements
