Progressive Eddy Current modeling via a finite element subproblem method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The modeling of eddy currents in conductors is split into a sequence of progressive finite element subproblems. The source fields generated by the inductors alone are calculated at first via either the Biot- Savart law or finite elements. The associated reaction fields for each added conductive region, and in return for the source regions themselves when massive, are then calculated with finite element models, possibly with initial perfect conductor and/or impedance boundary conditions to be further corrected. The resulting subproblem method allows efficient solving of parameterized analyses thanks to a proper mesh for each subproblem and the reuse of previous solutions to be locally corrected.
Fichier non déposé
hal-00917282 , version 1 (11-12-2013)
  • HAL Id : hal-00917282 , version 1
Patrick Dular, Victor Péron, Laurent Krähenbühl, Christophe Geuzaine. Progressive Eddy Current modeling via a finite element subproblem method. ISEF, Sep 2013, Ohrid, Macedonia. ⟨hal-00917282⟩
239 Consultations
0 Téléchargements
