Comparison of high order algorithms in Aerosol and Aghora for compressible flows - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Proceedings Année : 2013
This article summarizes the work done within the Colargol project during CEMRACS 2012. The aim of this project is to compare the implementations of high order finite element methods for compressible flows that have been developed at ONERA and at INRIA for about one year, within the Aghora and Aerosol libraries.
colargol.pdf (855.92 Ko) Télécharger le fichier
hal-00917411 , version 1 (11-12-2013)
Dragan Mbengoue, Damien Genet, Cedric Lachat, Emeric Martin, Maxime Mogé, et al.. Comparison of high order algorithms in Aerosol and Aghora for compressible flows. ESAIM: Proceedings, 2013, 43, pp.1-16. ⟨10.1051/proc/201343001⟩. ⟨hal-00917411⟩
523 Consultations
321 Téléchargements
