Fully decoupled time-marching schemes for incompressible fluid/thin-walled structure interaction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational Physics Année : 2015
In this paper we introduce a class of fully decoupled time-marching schemes (velocity-pressure-displacement splitting) for the coupling of an incompressible fluid with a thin-walled elastic or viscoelastic structure. The time splitting combines a projection method in the fluid with a specific Robin-Neumann treatment of the interface coupling. A priori energy estimates guaranteeing unconditional stability are established for some of the schemes. The accuracy and performance of the methods proposed is illustrated by a thorough numerical study.
RR-8425.pdf (11.16 Mo) Télécharger le fichier
hal-00918498 , version 1 (13-12-2013)
hal-00918498 , version 2 (09-01-2014)
hal-00918498 , version 3 (09-12-2014)
hal-00918498 , version 4 (06-05-2015)
Miguel Angel Fernández, Mikel Landajuela, Marina Vidrascu. Fully decoupled time-marching schemes for incompressible fluid/thin-walled structure interaction. Journal of Computational Physics, 2015, 297, pp.156-181. ⟨10.1016/j.jcp.2015.05.009⟩. ⟨hal-00918498v4⟩
385 Consultations
540 Téléchargements
