Efficient pricing of swing options in Lévy-driven models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Quantitative Finance Année : 2013
Antonino Zanette
  • Fonction : Auteur
  • PersonId : 949817
We consider the problem of pricing swing options with multiple exercise rights in Lévy-driven models. We propose an efficient Wiener-Hopf factorisation method that solves multiple parabolic partial integro-differential equations associated with the pricing problem. We compare the proposed method with a finite difference algorithm. Both proposed deterministic methods are related to the dynamic programming principle and lead to the solution of a multiple optimal stopping problem. Numerical examples illustrate the efficiency and the precision of the proposed methods.
QuF4.pdf (158.77 Ko) Télécharger le fichier
hal-00918582 , version 1 (17-12-2013)
Oleg Kudryavtsev, Antonino Zanette. Efficient pricing of swing options in Lévy-driven models. Quantitative Finance, 2013, 13 (4), pp.627-635. ⟨10.1080/14697688.2012.717708⟩. ⟨hal-00918582⟩
210 Consultations
359 Téléchargements
