On the Reliability of Wireless Sensor Networks Communications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Alexandre Mouradian
  • Fonction : Auteur
  • PersonId : 915176
Isabelle Augé-Blum
  • Fonction : Auteur
  • PersonId : 836658
More and more Wireless Sensor Networks (WSNs) applica- tions and protocols are proposed. Notably, critical applications, which must meet time and reliability requirements. Works on the real-time ca- pability of WSNs have been proposed [1]. In this paper we propose to study the achievable reliability of WSNs, tacking into account the prob- abilistic nature of the radio link. We define the reliability of a WSN to be the probability that an end-to-end communication is successful (i.e. the packet is received by the sink). We propose a theoretical framework inspired by a reference model [5]. We use the framework to derive the reliability of two types of routing schemes: unicast-based and broadcast- based. We show that in the case of broadcast-based, the sink is a relia- bility bottleneck of the network. We also discuss the impact of the MAC scheme on the reliability.
adhocnow13.pdf (292.81 Ko) Télécharger le fichier
hal-00918595 , version 1 (13-12-2013)
  • HAL Id : hal-00918595 , version 1
Alexandre Mouradian, Isabelle Augé-Blum. On the Reliability of Wireless Sensor Networks Communications. ADHOC-NOW 2013, Jul 2013, Wroclaw, Poland. p.38-49. ⟨hal-00918595⟩
169 Consultations
252 Téléchargements
