A Low-Latency Service Composition Approach in Mobile Ad Hoc Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In order to offer complex services to the users, separate services located at different devices in MANET should be composed in a mobile ad hoc network. A distributed approach to search for the Service Composition Path (SCP) with a low latency is proposed, which is based on two methods, Path Filtering and Path Combination. These two methods avoid unnecessary message transmissions, and greatly improve the searching efficiency. The experiment results show the superiorities of the approach to its counterpart.
SAC2014.pdf (315.7 Ko) Télécharger le fichier
hal-00918910 , version 1 (16-12-2013)
Chenyang Liu, Jian Cao, Frédéric Le Mouël. A Low-Latency Service Composition Approach in Mobile Ad Hoc Networks. 29th Annual ACM Symposium on Applied Computing (SAC'2014), Mar 2014, Gyeongju, North Korea. pp.509--511, ⟨10.1145/2554850.2555116⟩. ⟨hal-00918910⟩
242 Consultations
490 Téléchargements
