Rmixmod: The R Package of the Model-Based Unsupervised, Supervised and Semi-Supervised Classification Mixmod Library - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Statistical Software Année : 2015
Mixmod is a well-established software package for fitting a mixture model of multivariate Gaussian or multinomial probability distribution functions to a given data set with either a clustering, a density estimation or a discriminant analysis purpose. The Rmixmod S4 package provides a bridge between the C++ core library of Mixmod (mixmodLib) and the R statistical computing environment. In this article, we give an overview of the model-based clustering and classification methods, and we show how the R package Rmixmod can be used for clustering and discriminant analysis.
article.pdf (705.55 Ko) Télécharger le fichier
hal-00919486 , version 1 (16-12-2013)
Rémi Lebret, Serge Iovleff, Florent Langrognet, Christophe Biernacki, Gilles Celeux, et al.. Rmixmod: The R Package of the Model-Based Unsupervised, Supervised and Semi-Supervised Classification Mixmod Library. Journal of Statistical Software, 2015, 67 (6), pp.241-270. ⟨10.18637/jss.v067.i06⟩. ⟨hal-00919486⟩
901 Consultations
796 Téléchargements
