Robust Output Stabilization of Time-Varying Input Delay Systems using Attractive Ellipsoid Method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The problem of output control design for linear system with unknown and time-varying input delay, bounded exogenous disturbances and bounded deterministic measurement noises is considered. The prediction technique is combined with Luenberger-like observer design in order to provide the stabilizing output feedback. The scheme of parameters tuning for reduction of measurement noises effect and exogenous disturbances effects is developed basing on Attractive Ellipsoids Method. Under some restrictions it is formalized as semidefinite programming problem. The theoretical results are supported by numerical simulations.
Automatique
IEM_ID.pdf (168.75 Ko) Télécharger le fichier
hal-00920047 , version 1 (17-12-2013)
  • HAL Id : hal-00920047 , version 1
Andrey Polyakov, Alexander Poznyak, Jean-Pierre Richard. Robust Output Stabilization of Time-Varying Input Delay Systems using Attractive Ellipsoid Method. IEEE Conference on Decision and Control, IEEE, Dec 2013, Florence, Italy. pp.934-939. ⟨hal-00920047⟩
139 Consultations
328 Téléchargements
