Virtual/Real Transfer in a Large-Scale Environment: Impact of Active Navigation as a Function of the Viewpoint Displacement Effect and Recall Tasks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Advances in Human-Computer Interaction Année : 2013
The purpose of this study was to examine the effect of navigation mode (passive versus active) on the virtual/real transfer of spatial learning, according to viewpoint displacement (ground: 1m 75 versus aerial: 4m) and as a function of the recall tasks used. We hypothesize that active navigation during learning can enhance performances when route strategy is favored by egocentric match between learning (ground-level viewpoint) and recall (egocentric frame-based tasks). Sixty-four subjects (32 men and 32 women) participated in the experiment. Spatial learning consisted of route learning in a virtual district (four conditions: passive/ground, passive/aerial, active/ground, or active/aerial), evaluated by three tasks: wayfinding, sketch-mapping, and picture-sorting. In the wayfinding task, subjects who were assigned the ground-level viewpoint in the virtual environment (VE) performed better than those with the aerial-level viewpoint, especially in combination with active navigation. In the sketch-mapping task, aerial-level learning in the VE resulted in better performance than the ground-level condition, while active navigation was only beneficial in the ground-level condition. The best performance in the picture-sorting task was obtained with the ground-level viewpoint, especially with active navigation. This study confirmed the expected results that the benefit of active navigation was linked with egocentric frame-based situations.
Psychologie
hal-00920621 , version 1 (18-12-2013)
Gregory Wallet, Hélène Sauzéon, Florian Larrue, Bernard N'Kaoua. Virtual/Real Transfer in a Large-Scale Environment: Impact of Active Navigation as a Function of the Viewpoint Displacement Effect and Recall Tasks. Advances in Human-Computer Interaction, 2013, ⟨10.1155/2013/879563⟩. ⟨hal-00920621⟩
Collections
CNRS INRIA INRIA2
166 Consultations
0 Téléchargements
