Synchrony weakened by message adversaries vs asynchrony restricted by failure detectors
A message adversary is a daemon that suppresses messages in round-based message-passing synchronous systems in which no process crashes. A property imposed on a message adversary defines a subset of messages that cannot be eliminated by the adversary. It has recently been shown that when a message adversary is constrained by a property denoted TOUR (for tournament), the corresponding synchronous system and the asynchronous crash-prone read/write system have the same computability power for task solvability. This paper introduces new message adversary properties (denoted SOURCE and QUORUM), and shows that the synchronous round-based systems whose adversaries are constrained by these properties are characterizations of classical asynchronous crash-prone systems (1) in which processes communicate through atomic read/write registers or point-to-point message-passing, and (2) enriched with failure detectors such as Ω and Σ. Hence these properties characterize maximal adversaries, in the sense that they define strongest message adversaries equating classical asynchronous crash-prone systems. They consequently provide strong relations linking round-based synchrony weakened by message adversaries with asynchrony restricted with failure detectors. This not only enriches our understanding of the synchrony/asynchrony duality, but also allows for the establishment of a meaningful hierarchy of property-constrained message adversaries.
Cet article étudie les relations entre les modèles synchrones affaiblis par des adversaires supprimant des messages et les modèles asynchrones renforcés par des détecteurs de fautes.
