Canonical polyadic decomposition of complex-valued multi-way arrays based on simultaneous Schur decomposition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we propose a new semi-algebraic algorithm to compute the Canonical Polyadic (CP) decomposition of complex-valued multi-way arrays. The proposed algorithm is based on the Simultaneous Schur Decomposition (SSD) of particular matrices derived from the array to process. This CP algorithm solves some convergence problems of classical iterative techniques and its identifiability assumptions are less restrictive than those of other semi-algebraic methods. We also propose a new Jacobi-like algorithm to calculate the SSD of several complex-valued matrices. Finally the usefulness of the proposed method is illustrated in the context of fluorescence spectroscopy and epileptic source localization.
HajiASM13-ICASSP_final_version_.pdf (220.08 Ko) Télécharger le fichier
hal-00921783 , version 1 (21-12-2013)
  • HAL Id : hal-00921783 , version 1
Sepideh Hajipour, Laurent Albera, Mohammad B. Shamsollahi, Isabelle Merlet. Canonical polyadic decomposition of complex-valued multi-way arrays based on simultaneous Schur decomposition. 2013 IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP), May 2013, Vancouver, Canada. pp.4178-4182. ⟨hal-00921783⟩
457 Consultations
331 Téléchargements
