Jacobi-like nonnegative joint diagonalization by congruence - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A new joint diagonalization by congruence algorithm is presented, which allows the computation of a nonnegative joint diagonalizer. The nonnegativity constraint is ensured by means of a square change of variable. Then we propose a Jacobi-like approach using LU matrix factorization, which consists of formulating a high-dimensional optimization problem into several sequential one-dimensional subproblems. Numerical experiments emphasize the advantages of the proposed method, especially in the presence of bottlenecks such as for low SNR values and a small number of available matrices. An illustration of blind source separation shows the interest of the proposed algorithm.
WangASS13-EUSIPCO_final_version_.pdf (357.15 Ko) Télécharger le fichier
hal-00921807 , version 1 (21-12-2013)
  • HAL Id : hal-00921807 , version 1
Lu Wang, Laurent Albera, Huazhong Shu, Lotfi Senhadji. Jacobi-like nonnegative joint diagonalization by congruence. XXI European Signal Processing Conference (EUSIPCO'13), Sep 2013, Marrakech, Morocco. 5 p. ⟨hal-00921807⟩
514 Consultations
212 Téléchargements
