A glimpse on passive control using porous media for incompressible aerodynamics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Aerodynamics Année : 2014
The control of two-dimensional flows around bluff-bodies is achieved using porous devices added to some parts of the body. The bodies can be square or circular cylinders as well as a moving Ahmed body on the top of a road. The flow in different media is modelled by means of the penalization method. A good choice of the location of the porous interfaces yields a significant improvement of the aerodynamic quantities. Finally, a coupled active/passive control is presented in order to achieve a better drag reduction.
Fichier non déposé
hal-00922032 , version 1 (23-12-2013)
  • HAL Id : hal-00922032 , version 1
Charles-Henri Bruneau, Emmanuel Creusé, Patrick Gilliéron, Iraj Mortazavi. A glimpse on passive control using porous media for incompressible aerodynamics. International Journal of Aerodynamics, 2014, 4 (1/2), pp.70-86. ⟨hal-00922032⟩
240 Consultations
0 Téléchargements
