Single input controllability of a simplified fluid-structure interaction model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Control, Optimisation and Calculus of Variations Année : 2013
In this paper we study a controllability problem for a simpli ed one dimensional model for the motion of a rigid body in a viscous uid. The control variable is the velocity of the uid at one end. One of the novelties brought in with respect to the existing literature consists in the fact that we use a single scalar control. Moreover, we introduce a new methodology, which can be used for other nonlinear parabolic systems, independently of the techniques previously used for the linearized problem. This methodology is based on an abstract argument for the null controllability of parabolic equations in the presence of source terms and it avoids tackling linearized problems with time dependent coefficients.
hal-00922193 , version 1 (24-12-2013)
Yuning Liu, Takéo Takahashi, Marius Tucsnak. Single input controllability of a simplified fluid-structure interaction model. ESAIM: Control, Optimisation and Calculus of Variations, 2013, 19 (1), pp.20-42. ⟨10.1051/cocv/2011196⟩. ⟨hal-00922193⟩
466 Consultations
0 Téléchargements
