OLA in the OAEI 2005 alignment contest - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
Among the variety of alignment approaches (e.g., using machine learning, subsumption computation, formal concept analysis, etc.) similarity-based ones rely on a quantitative assessment of pair-wise likeness between entities. Our own alignment tool, OLA, features a similarity model rooted in principles such as: completeness on the ontology language features, weighting of different feature contributions and mutual influence between related ontology entities. The resulting similarities are recursively defined hence their values are calculated by a step-wise, fixed-point-bound approximation process. For the OAEI 2005 contest, OLA was provided with an additional mechanism for weight determination that increases the autonomy of the system.
paper15.pdf (165.12 Ko) Télécharger le fichier
hal-00922284 , version 1 (25-12-2013)
  • HAL Id : hal-00922284 , version 1
Jérôme Euzenat, Philippe Guégan, Petko Valtchev. OLA in the OAEI 2005 alignment contest. Proc. K-Cap 2005 workshop on Integrating ontology, Oct 2005, Banff, Canada. pp.97-102. ⟨hal-00922284⟩
195 Consultations
143 Téléchargements
