Adaptive Register Allocation with a Linear Number of Registers
We give an adaptive algorithm in which processes use multi-writer multi-reader registers to acquire exclusive write access to their own single-writer, multi-reader registers. It is the first such algorithm that uses a number of registers linear in the number of participating processes. Previous adaptive algorithms require at least Θ(n 3/2) registers.
