High-quality construction of analysis-suitable trivariate NURBS solids by reparameterization methods - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computational Mechanics Année : 2014
Gang Xu
  • Fonction : Auteur
  • PersonId : 899052
Bernard Mourrain
Timon Rabczuk
  • Fonction : Auteur
  • PersonId : 955097
High-quality volumetric parameterization of computational domain plays an important role in three-dimensional isogeometric analysis. Reparameterization technique can improve the distribution of isoparametric curves/surfaces without changing the geometry. In this paper, using the reparameterization method, we investigate the high-quality construction of analysis-suitable NURBS volumetric parameterization. Firstly, we introduce the concept of volumetric reparameterization, and propose an optimal Möbius transformation to improve the quality of the isoparametric structure based on a new uniformity metric. Secondly, from given boundary NURBS surfaces, we present a two-stage scheme to construct the analysis-suitable volumetric parameterization: in the first step, uniformity-improved reparameterization is performed on the boundary surfaces to achieve high-quality isoparametric structure without changing the shape; in the second step, from a new variational harmonic metric and the reparameterized boundary surfaces, we construct the optimal inner control points and weights to achieve an analysis-suitable NURBS solid. Several examples with complicated geometry are presented to illustrate the effectiveness of proposed methods.
template.pdf (946.35 Ko) Télécharger le fichier
Format : Figure, Image
hal-00922544 , version 1 (27-12-2013)
hal-00922544 , version 2 (08-01-2015)
Gang Xu, Bernard Mourrain, André Galligo, Timon Rabczuk. High-quality construction of analysis-suitable trivariate NURBS solids by reparameterization methods. Computational Mechanics, 2014, 54 (5), pp.1303-1313. ⟨10.1007/s00466-014-1060-y⟩. ⟨hal-00922544v2⟩
1197 Consultations
711 Téléchargements
