What can be decided locally without identifiers? - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2013
Do unique node identifiers help in deciding whether a network $G$ has a prescribed property $P$? We study this question in the context of distributed local decision, where the objective is to decide whether $G \in P$ by having each node run a constant-time distributed decision algorithm. If $G \in P$, all the nodes should output yes; if $G \notin P$, at least one node should output no. A recent work (Fraigniaud et al., OPODIS 2012) studied the role of identifiers in local decision and gave several conditions under which identifiers are not needed. In this article, we answer their original question. More than that, we do so under all combinations of the following two critical variations on the underlying model of distributed computing: ($B$): the size of the identifiers is bounded by a function of the size of the input network; as opposed to ($\neg B$): the identifiers are unbounded. ($C$): the nodes run a computable algorithm; as opposed to ($\neg C$): the nodes can compute any, possibly uncomputable function. While it is easy to see that under ($\neg B, \neg C$) identifiers are not needed, we show that under all other combinations there are properties that can be decided locally if and only if identifiers are present. Our constructions use ideas from classical computability theory.
Dates and versions
hal-00912527 , version 1 (02-12-2013)
Identifiers
Cite
Pierre Fraigniaud, Mika Göös, Amos Korman, Jukka Suomela. What can be decided locally without identifiers?. PODC 2013 - ACM Symposium on Principles of Distributed Computing, Jul 2013, Montreal, Canada. pp.157-165, ⟨10.1145/2484239.2484264⟩. ⟨hal-00912527⟩
120 View
0 Download
Share
